HIGH HP M CLUTCH SETUP
TONY J
12-31-2005 13:09:55
was wondering what kind of clutch setups you guys with big hp are runningon your m's (150hp+)...also who does the best carb work around. any input appreciated
thks
tony
Gary Baker
01-01-2006 06:43:04
 Re: HIGH HP M CLUTCH SETUP in reply to TONY J, 12-31-2005 13:09:55
Go to your local Tractor Dealer and order through AP (Ag Parts) a clutch disk Heavy Duty 6 button for a Super 'M'. For the pressure plate Order a HD Pressure Plate for a 986 Hydraulic asist Peddel. Grind off the splined hub rivits on cover of pressure plate and discard hub. Works very good. Be sure to have flywheel surfaced. This set-up will hold 150HP easy. Oh, by the way you must use a Super 'M'-450 flywheel.
TONY J
01-01-2006 08:26:52
 Re: HIGH HP M CLUTCH SETUP in reply to Gary Baker, 01-01-2006 06:43:04
thks greatly, do you have any ideas on a stock style carb for an m like that....looks like your m is running good..
thks
again
tony
Gary Baker
01-01-2006 13:47:55
 Re: HIGH HP M CLUTCH SETUP in reply to TONY J, 01-01-2006 08:26:52
Yes, I rework the stock 'M' carb. I am running an 'M' carb on my tractor.
TONY J
01-01-2006 20:22:58
 Re: HIGH HP M CLUTCH SETUP in reply to Gary Baker, 01-01-2006 13:47:55
tried to send once, but i dont think it went through..Gary my email is [email protected],send me a way to get ahold of ya via phone or email,if ya would
thks
tony
