JD A pistons
Jerry Riesenber
12-30-2005 17:08:01
will 620 lp pistons fit into a late model a block? will this give more compression than aftermarket M&W's?
Lynard
12-31-2005 08:35:17
 Re: JD A pistons in reply to Jerry Riesenberg, 12-30-2005 17:08:01
Jerry Yes and no. Lynn
Jerry Riesenberg
12-31-2005 10:31:33
 Re: JD A pistons in reply to Lynard, 12-31-2005 08:35:17
would the 620 bore be to big? or the length of the piston be different? looking for a piston to fit a late A block. just using the J.D. A for some plowing and fun.
Lynard
01-01-2006 15:54:41
 Re: JD A pistons in reply to Jerry Riesenberg, 12-31-2005 10:31:33
Jerry You can use the M & W pistons and they will give you around 6.5:1 compression. If you want more comrpession cut .125 inch off the head and this will give you a little over 7.0:1. Lynn
Drew
12-31-2005 10:35:58
The bore on the two is the same. I'm pretty sure a 620 piston is shorter though. I know where there is a set of +.090 A pistons at.
yes.....
12-31-2005 23:59:52
 Re: JD A pistons in reply to Drew, 12-31-2005 10:35:58
the 620 pistons are about 1 " shorter...
buickanddeere
12-31-2005 15:36:32
620 has a larger bore and a shorter stroke than the A or 60. A set of 45 over LP pistons for a model 60 and a cam from Roberts Carb will perk the old girl up. May as well blend the valve bowls, port match and do a multi-angle valve job too.
johndear
01-01-2006 07:07:57
 Re: JD A pistons in reply to buickanddeere, 12-31-2005 15:36:32
So the compression height on a 620 piston is less than an A? Someone selling pistons claimed the 620 piston had nearly an inch more "piston" above the pin than the A piston. Guess it depends on what you are comparing (lp to all fuel). What piston would make a good replacement for an A with a longer compression height than the A? Something that is available over the counter in a .125" over bore.
Thanks,
John
buickanddeere
01-01-2006 19:53:53
 Re: JD A pistons in reply to johndear, 01-01-2006 07:07:57
You will not see any HP differenc ebetween a 45 over vs. a 125 overbore. Good late A/60 blocks are getting hard to find. No use going 90 or 125 unless you really have to, save some metal for next time.
Drew
12-31-2005 18:07:14
620/630 is 5.500"x6.375". Which Roberts cam, puller grind #1 or puller grind #2? He may do good carb work, but I question some of his performace ideas. He told me that I should use his camshaft and then I didnt need high ratio rockers. Long story short, I used another camshaft that didnt have a mile and a half of lobe lift and the rocker arms that he said I didnt need, and gained 12hp. This is why I will NEVER have a camshaft from Roberts.
