Weight location
Jason(Pa.)
12-29-2005 18:03:19
A Friend and I were talking about where to put the weights on his puller he has been messing around with. I would feel (and heard)that if you put the weights on the back of a tractor it is best to have them as close to the tractor and down as far as possable to the ground. He kind of doesn't agree with my thinking and I was just wondering what you all may feel about it. Thanks!
MDOG
12-31-2005 07:13:52
 Re: Weight location in reply to Jason(Pa.), 12-29-2005 18:03:19
Dont know about height of the weights. Might make a difference if you get the front way off the ground, but if you are close on balance I dont think height will matter. Where to put as far as front to rear? This will depend on the track and your tractor. I usually run twice as much on the rear as the nose and put the rest on the middle. All of this takes experimentation, so get out and pull. Each hook is knowledge gained the best way.
Jerry Cent. Mi.
12-30-2005 04:49:17
It also depends on where you can find the space for the weights without going past the rear wheels. Some clubs won't let you past the hooking point.
Dave in MN
12-29-2005 20:05:14
An older tractor puller friend of mine once told me that there is some physics? (sounded good to me) formula that stated that for every 1 foot from the pivot point (rear axel), the weight multiplies once. 500# directly on axel (wheel weights) equals 500#....500# 18 inches behind axel equals 1250# ({500# X 1.5} + the origional 500# =1250)...200# 11 feet from rear axel (on front end) equals 2400# ({200X11} + 200=2400)
The height of weight MIGHT make a differance on front of tractor... keeping weight as low as possible below line of balance should help, not sure how much it will help, but every little bit helps. I've seen some low front weights fall off when they hit the scale when the tractor was driven on/off the scale.
Personally, I like mostly 100# (I take 30-100# along with 3-75# to help change weight to each pull) suitcase weights. Make your brackets so that you can EASILY take weights on and off...waist high works best for me. I take the weights off of tractor and lay on bed of trailer, all waist high.
Make sure that you can tie the weights down while your transport your tractor and while you are pulling.
Remember, having to move 10-100# weights 2, 3 or 4 times for each pull can get hard on your back, arms and leg muscles. Make the location of your brackets as handy as possible to get to.
hahter
12-29-2005 19:05:34
I believe that the issue of weight placement is a personal choose. I have seen tractors with weights upto the height of the seat of the tractor. I have weights on both sides of the axles, as well as wheel weights. So, you are right and depends on your friend's opinion he can be right. Your main goal is to get the best traction as possible so you want the best weight distribution as possible. Hope this helps.
Have a Happy New Year!!
ras sch pony express pt g
12-30-2005 18:02:24
 Re: Weight location in reply to hahter, 12-29-2005 19:05:34
IT DOSENT MATTER WHERE WEIGHT IS PLACED
12-30-2005 18:07:56
 Re: Weight location in reply to ras sch pony express pt g, 12-30-2005 18:02:24
IT DOSENT MATTER WHERE WEIGHT IS PLACED. AS LONG AS YOU DONT USE UNCALE FRED THAT WAS BEFORE NTPA WAS FORMED. WHEN YOU SIT ON FRONT YOU CANT TELL WHERE WEIGHT SHOULD BE PLACED ANY WAYS JUST ASK MILTON B I HAVE THROWN MORE WEIGHT IN ONE YEAR THAN MOST IN LIFE TIME
