john deere a starter mount
mudsucker
12-28-2005 13:39:09
Anyone out there build or know of someone who builds the top starter mount/crankcase cover out of steel? I appreciate any ideas and suggestions.
blackwidow
12-29-2005 18:44:33
 Re: john deere a starter mount in reply to mudsucker, 12-28-2005 13:39:09
we have built several. we used3/8 plate and 1/2 for the up right. used old strater housing for pattern. be sure to get enough clearence between starter and flywheel.usually masking tape is enough.
mudsucker
12-30-2005 06:07:39
 Re: john deere a starter mount in reply to blackwidow, 12-29-2005 18:44:33
Blackwidow, do you mean clearance between the bendix and the ring gear? Also, were you able to use flat steel or did you need to mill or fabricate clearance for your rods.
