1939 H and M top covers???
STRANGE BREW
12-20-2005 20:50:59
Hey guys, is there any demand any more for the 39 transmission covers for the H's and M's?? If so, what are some going prices? Serial tags? Thanks for any info!
BENCIE
12-22-2005 14:48:07
 Re: 1939 H and M top covers??? in reply to STRANGE BREW, 12-20-2005 20:50:59
39 M'S DIDN'T HAVE SERIAL TAGS JUST SERIAL STAMPED INTO TOP OF FRAME RAIL.
mpuller2
12-22-2005 16:07:44
 Re: 1939 H and M top covers??? in reply to BENCIE, 12-22-2005 14:48:07
I have 5 39 M farmalls. All have s# tags along with matching # on top of frame rail.
BENCIE
12-22-2005 17:46:32
 Re: 1939 H and M top covers??? in reply to mpuller2, 12-22-2005 16:07:44
SERIAL # 874 DOES NOT HAVE A SERIAL # TAG NOR DOES IT HAVE ANY HOLES IN THE BELL WHERE THERE EVER WAS ONE.
randy hall
12-22-2005 20:41:48
 Re: 1939 H and M top covers??? in reply to BENCIE, 12-22-2005 17:46:32
i have #691 and it has the holes for the serial nunber tag.
mpuller2
12-22-2005 17:52:16
Maybe tag is missing and holes filled with grease, paint or cow manure. All 39 M's I ever saw had a tag.
BENCIE
12-22-2005 18:12:47
 Re: 1939 H and M top covers??? in reply to mpuller2, 12-22-2005 17:52:16
MPULLER2, I'M NOT TRYING TO GET INTO A SQUIRTING CONTEST WITH YOU. THIS M WAS COMPLETELY SANDBLASTED AND NO HOLES WERE FOUND. I ASKED SOME OTHER FELLOWS ABOUT IT AND WAS TOLD 39'S WERE LIKE THE F20'S WITH THE # STAMPED IN THE FRAME. I HAVE NOT SEEN ANOTHER 39 TO LOOK AT. IF YOU HAVE 5 OF THEM WITH TAGS THEN THEY MUST HAVE HAD TAGS FROM NEW I'M NOT DOUBTING YOU. ARE THEY LATER VIN'S? HOW MANY WERE BUILT IN 39?
39 FARMALL M
12-23-2005 10:29:50
 Re: 1939 H and M top covers??? in reply to BENCIE, 12-22-2005 18:12:47
FROM WHAT IHAVE SEEN AND HEARD, THE EARLY M"S HAD THE FRAME STAMPED UP UNTIL 2500 OR SO.VERY VERY EARLY DIDNT HAVE TAGS. HAVE SEEN A COUPLE OF THE FIRST 200 AND NO TAGS AND NO HOLES FOR TAGS, JUST STAMPED FRAME AND ENGINE SERIAL NUMBER.
Flyin Farmall
12-26-2005 13:52:51
 Re: 1939 H and M top covers??? in reply to 39 FARMALL M, 12-23-2005 10:29:50
My 41 M has the frame stamped also.I have seen some very early M"s 5## with a serial tag.
mpuller2
12-22-2005 21:01:34
I'll look up numbers and report back. I know one is quit early, other 4 in middle of production numbers. It will be after Christmas before I get to shop and get numbers. Have a nice Christmas.
randy hall
12-22-2005 20:44:20
yes the number was stamped on the frame rail just like the f-20's and the f-20's had a serial number tag also.
Mcred
12-22-2005 13:38:11
Are you parting out 1939 M's? if so were are you located i need parts for a 39 M I am wantig to restore for show use and prefer to have the "I" cast codes.
LBSIAMJS
12-21-2005 17:13:32
How much lighter are the 39 cover vers the later covers.
Jon Aller
12-21-2005 05:40:16
I don't know about M's but on H's the '39 cover is much lighter than the regular cover. As for the cover and the serial number tag, yes those are desirable as a pair but if you put them on a non '39 tractor it shouldn't make it any more collectable. Anyone that knows the casting codes can tell it is not a '39.
STRANGE BREW
12-21-2005 10:35:22
 Re: 1939 H and M top covers??? in reply to Jon Aller, 12-21-2005 05:40:16
Yeah as far as collecting I know, but I wonder if pullers are still looking for them??
Cody
12-21-2005 13:37:04
 Re: 1939 H and M top covers??? in reply to STRANGE BREW, 12-21-2005 10:35:22
I would think, with all of the aluminum tops being made, that the demand for the 39' slot tops has decreased dramatically.
