U Moline Stroke
Kenny G
12-18-2005 18:22:28
I have a U moline that I want to put a G crank in,how much more stroke can I add without a lot of grinding.Any ideas on what jugs to use. THANKS
mohead10
12-20-2005 17:26:43
 Re: U Moline Stroke in reply to Kenny G, 12-18-2005 18:22:28
a very nice motor for a u is 4.810 ross piston part#105085a. with afarmall m rod you will end up with 6.75 or more stroke.
Mopower
12-21-2005 05:35:41
 Re: U Moline Stroke in reply to mohead10, 12-20-2005 17:26:43
How much is crank welding and how much is offset grinding? Sounds like a nice set-up.
mohead10
12-21-2005 14:01:51
 Re: U Moline Stroke in reply to Mopower, 12-21-2005 05:35:41
call todd at t n t machine. about 1500.00 to stroke the crank. with the farmall m rods not much grinding to do. m rods balance nicer than u rods. plus is a longer rod. wich gives you a better rod angle. all helps to gane HP.
Your Kidding
12-22-2005 02:14:21
 Re: U Moline Stroke in reply to mohead10, 12-21-2005 14:01:51
I was wanting to stoke my U. 6 to 7 inch but had no idea that it would cost any where close to that much.And then how much for the pistons.
mohead10
12-22-2005 14:34:15
 Re: U Moline Stroke in reply to Your Kidding, 12-22-2005 02:14:21
well if you like the ross pistons. at 4.810 bore. and a good set of rings. about 900.00 to 1000.00 will be a good start.
Mopower
12-20-2005 05:43:39
7 inches is pretty standard although 7.5 is easier with tall G blocks and a big bore setup. You can get U or G jugs with a 5.75 bore (for a price). Otherwise using M5 blocks and boring to 4.81 is as big as you can go without special work.
minnie ub
12-19-2005 06:17:30
what rods are you planning on using
Kenny G
12-19-2005 09:32:58
 Re: U Moline Stroke in reply to minnie ub, 12-19-2005 06:17:30
Talked about H Farmall or wakasha forgive the spelling.
minnie ub
12-19-2005 18:51:51
 Re: U Moline Stroke in reply to Kenny G, 12-19-2005 09:32:58
I don't think the m rods are strong enough but there are alot of molines running them successfully. There is less grinding with m rods. We used our u rods but it took more grinding.I like to stay at 6.75 to 7 inch stroke because I think going bigger shortens the life of the motor.If your pockets are deep go custom rods and go on up to 7.25 to 7.5. My pockets were never that deep.
Jeff A. Gravert
12-22-2005 18:18:53
 Re: U Moline Stroke in reply to minnie ub, 12-19-2005 18:51:51
Spend the money and buy a good quality custom rod. My pockets were never big enough either. Although the old 5 star is not much fun sitting in the shed with the M rods hanging out the side. Pay me now or pay later.
