Allis C puller
TS
12-15-2005 14:01:12
Aneyone have a idea what HP you can make out of a stock oversize kit for a B or C? I dont want to use any other block, Our rules wont alow it just oversize kits and what size tires shuld i use we can go to 13.6 top cut tires, I just need some ideas, With the price of fule these days i am thinking small tractors need less fule to take them there and back and there just as much Fun for me.
LWD
12-17-2005 17:39:17
 Re: Allis C puller in reply to TS, 12-15-2005 14:01:12
I fore got you will have to find a piston with the right deck hight so you dont bump the head.
LWD
12-17-2005 17:34:25
You will have to bore the c block a little from the top counter bore down, the D-14 and the C have the same size counter bore, the front hole you will have to watch the water pump bolt boss that cast in the water jacket. you can cut the `o` ring groves on the mill,or use devcon(flexame 80 liquid 15800)hope this helps.
H.B. Hutchens
12-16-2005 18:19:47
D14 piston will fit, a little longer, what do you do about O rings, C has them in sleeves and D14 , they are in block, been wanting to do that to my C. H.B.
LWD
12-16-2005 15:09:10
Did you think of a ca 4 speed trans. D-14 sleves and pistons? grind a D14 crank to fit? do they want you to pull in low, or can you pull in any gear? tire size? the C is a fun tractor to pull with.
TS
12-17-2005 04:24:02
 Re: Allis C puller in reply to LWD, 12-16-2005 15:09:10
How big are the pistons and stroke on a D 14? We have a speed limit of 3.5mph any gear and tires i have now work great and there 12.4 24 but i was thinking about 13.6 28 like some of others tractors have i pull agenst to keep my speed up in 1st gear and keep down to our RPM limit of 10% over, You guys never used a 3 7/16 over size kit and checked it for HP ? We are only pulling in 2500lb, 3000lb, and on a loose track maby 3500lbs class and useing D 14 parts is kinda like breaking our rules of oversize kits.
