venturi
champspa
12-14-2005 13:57:59
does anyone have the small dia of the venturi for a 450 farmall and what it should be if it had over 200psi cylinder pressure
JakeF
12-14-2005 17:54:53
 Re: venturi in reply to champspa, 12-14-2005 13:57:59
The # will tell you the size in 32nds of an inch. A 33 is 1 1/32"
REDEYE
12-14-2005 16:25:20
450 venturi is a #29 meaning it is .906" If you ask 5 different people what size you should run you will get 5 different answers. Every tractor is different. Only way to get it just right is to take the time and figure out what she likes by boring it out on a lathe and testing. Or, if you want to take a shortcut you have the following options:
#29- 400-450-and some 460"s
#30- 6 cyl, 263ci
#33- 6 cyl-291-and some 301"s
#35- 301 (715 motor)
champspa
12-15-2005 13:04:43
 Re: venturi in reply to REDEYE, 12-14-2005 16:25:20
thanks to both of you for your answers I appreciate it very much
