Starters for High Compression G Puller.
Miller49G
12-14-2005 12:41:58
What type of starters do you guys use for your high compression John Deere G pullers? I heard that some of you use starters from a Bobcat and if so what"s the part # of the Bobcat starter.
Miller49G
Tree Topper
12-15-2005 13:58:41
 Re: Starters for High Compression G Puller. in reply to Miller49G, 12-14-2005 12:41:58
I have a 1950 G with a moderate sized engine,I put a reduction gear starter on it. The Delco part# is 1113278, comes with the correct starter drive will bolt right to the orginial starter mount. I am running 2 batteries and it spins the tractor real good. This starter was used on some of the first Ford Power Stroke Diesels. If you find one off of a Ford truck you will just have to change the starter drive.
Super Lurker
12-15-2005 05:35:36
The Bobcat number is 410-12139. About $275 new.
pullinA
12-15-2005 00:17:11
Will this same starter fit on a big cube 52 A, still in the original postion underneath? Or what do you use for this application?
G/MAN
12-15-2005 07:26:23
 Re: Starters for High Compression G Puller. in reply to pullinA, 12-15-2005 00:17:11
I've wondered about that, but haven't looked yet. I've got a "60", which of course uses the same starter location as a late "A". I think it MIGHT work, but a guy might have to re-index the motor to the drive, and I don't know if it will all fit above the plate on the bottom. Might have to make a deeper one or leave it off. I have to pull the starter off my "60" yet this winter, and when I do, I'll put my other gear-drive back together and do some test-fitting.
blackwidow
12-14-2005 18:43:42
you can get a brand new nip strater #128000-8293 tax inc, for 309.00. i got my strater from davenport starter in batesville ar.
champspa
12-14-2005 13:50:35
I think a cummins b engine has a starter that will spin it and will fit , 12volt much torque
G/MAN
12-14-2005 13:21:53
Gear-reduction Denso starter off a Deere 8000-series 6081 engine works like a charm. My friend replaced the 4430 starter on his 700-cube "G" with one and it is much more effective at cranking it than the 4430 unit. Part number TY24439 from Deere as a reman unit. $530 for a brand new one, part number RE70957. I don't know what Bobcat uses, but I doubt they're specced to crank a 16.5:1 496-cube engine.
REDEYE
12-14-2005 16:39:21
 Re: Starters for High Compression G Puller. in reply to G/MAN, 12-14-2005 13:21:53
G/MAN, do you know if that starter or another could replace a 2 or three bolt interntaional starter? I know that all starters are pretty much an SAE1, SAE2, or SAE3 bolt pattern, have different drive gears and can spin cw or ccw, but I dont know what will fit what.
G/MAN
12-15-2005 07:23:53
 Re: Starters for High Compression G Puller. in reply to REDEYE, 12-14-2005 16:39:21
I really don't know all that much about that end of it. All I know is that it's a 3-bolt pattern using 3/8" bolts. Another buddy of mine bolted one on his 4020. Said he had to do some modifying on the intake manifold, but after that, it works like a charm also.
G/MAN - OOPS...
12-14-2005 16:12:59
Forgot the reman starter price - $424.00.
Miller49g
12-14-2005 14:25:00
G/MAN,
That starter it is a bolt on unit or do you have to modify the mounting hole on the tractor.
G/MAN
12-14-2005 16:08:57
 Re: Starters for High Compression G Puller. in reply to Miller49g, 12-14-2005 14:25:00
Bolts right in the factory location, is correctly indexed, turns the right direction, engages the flywheel correctly and the whole nine yards. All you have to do is install a push-button to supply juice to the start-terminal. Found that one out when I bought my '48 "G" sans starter. Had a complete 8400 engine in the warehouse. Pulled the starter off just to see, as I knew the other "full-size" starters would fit and there was no difference in the mounting or anything on the 6081 engine. One customer got to asking about it, and we told him that we punched in the original "G" starter part number and it "subbed up" to that one, lol. I've got another one out of the warranty pile that needs reassembled, but I've got a place to go with that one.
Miller49G
12-14-2005 23:04:38
 Re: Starters for High Compression G Puller. in reply to G/MAN, 12-14-2005 16:08:57
G/MAN,
Sounds good to me again thanks for the info on the starter. Do you still have your "48 G and what kind of mods did you do to it.
G/MAN
12-15-2005 07:22:21
 Re: Starters for High Compression G Puller. in reply to Miller49G, 12-14-2005 23:04:38
I've still got it. I bought it without a starter in pretty rough shape, honed and re-ringed it and wanted to get it running just a little before completely going through it. Took it down to the bare main case and started over. Right now it's STILL not done. Rear axle is all back together and bolted to the main case, trans is all back together, frame is back on the main case, pedestal back on the frame, etc. It's pretty much over the hump as far as the major work goes, but it's stashed in the corner of a warehouse, and it'll take a couple days of moving just to get to it, lol. When done it'll be .125" over with aluminum hi-comps, mild porting on the head and gasket-matching, mild performance cam grind, and an offset grind with "A" rods for a little bit of stroke. I'd like to see 60 horses out of it with a good cold manifold, but don't know if I'll quite make it. I just want it to be a good solid Div. II tractor and a reliable plow tractor for playing in the dirt.
Miller49G
12-15-2005 08:17:22
 Re: Starters for High Compression G Puller. in reply to G/MAN, 12-15-2005 07:22:21
G/MAN,
What do you think about the Jerrys Weld & Machine head for the John Deere G. Would that head be good for stock stroke G with 6.250 bore and 9:1 compression with pulling cam and carb.
DP
12-17-2005 19:24:50
 Re: Starters for High Compression G Puller. in reply to Miller49G, 12-15-2005 08:17:22
Just my opinion, but I think your money would be better spent on a flat head. With the specs. your using, that should run out real nice for you.
G/MAN
12-15-2005 10:22:03
I think that head would be overkill on a stock-stroke tractor with that bore, but that's my opinion. Upgrading the camshaft and doing some good porting, polishing and gasket-matching should have a stock head flowing enough air to feed a "G" that size with ease. And there's always increased-ratio rockers to throw the valves open further. If you get TOO much port and valve size without the displacement to suck on it, you're going to end up with pretty low intake velocity and maybe not smuch swirl in the cylinders. My buddy has a Jerry's head and manifold on his 720-cube "G", and it's an excellent match. Good power throughout the rpm range and it pulls like crazy. There are several guys on this board that know WAY more about building "G"s than I do - Seamo, JDGnut, etc.
Miller49G
12-14-2005 13:50:01
G/MAN,
Thanks for the info on the starter.
george bush
12-14-2005 13:02:57
Around here guys use a log chain hooked to a CASE!!!
G/MAN
12-14-2005 13:22:27
 Re: Starters for High Compression G Puller. in reply to george bush, 12-14-2005 13:02:57
What are they pulling the Case with then???
Ol Gray a
12-14-2005 14:34:50
 Re: Starters for High Compression G Puller. in reply to G/MAN, 12-14-2005 13:22:27
A 2 year old on a tricycle
superih
12-14-2005 16:37:41
 Re: Starters for High Compression G Puller. in reply to Ol Gray a, 12-14-2005 14:34:50
Now thats funny I don't care who you are!!!
CASEPOWER
12-14-2005 14:32:29
An even smaller Case!
famous amos
12-15-2005 10:22:07
 Re: Starters for High Compression G Puller. in reply to CASEPOWER, 12-14-2005 14:32:29
2 year olds run binders real men run Case, you know, the company that bought IH out!!
