super m cyl kits
TOWBOATT
12-13-2005 18:10:34
just got a farmall m my first one.can any body give me some help?? will super m cyl. kits fit in a m block?
B barenie
12-15-2005 16:02:36
 Re: super m cyl kits in reply to TOWBOATT, 12-13-2005 18:10:34
If you want to put a 5.75 stroker in it, I have a set of custom pistons that will twist you up another (notch) !
bud barenie ph # 219.716.0467
Ben Rauls
12-14-2005 16:16:16
you can run sleeveless block and run 4.1/8 450 pistons
colekicker
12-13-2005 19:04:09
Ok, if you have a C-248 block, it was 3 7/8" bore factory. When you order a cyl kit for it, it should be at 4". This will take it to a 264 from the stock 248 cubes. But, look closely at your block to see what block you do have. Remember, lots of things can change in 50+ years.
