rules at tunica???
oliver puller
12-12-2005 18:32:08
Just want to know what rpm's do they run in 8mph and 12mph classes is it per tractor or is it across the broad. thanks for info
semoac
12-13-2005 04:09:17
 Re: rules at tunica??? in reply to oliver puller, 12-12-2005 18:32:08
The rpms on some tractors were way over.just for an example there was a black primer oliver with red wheels that sound like he was 50-75%over.
Spotter
12-12-2005 21:16:08
20% over for 4&8MPH classes. 30% over for 12MPH's.
Spotter
To Bad
12-14-2005 07:26:43
 Re: rules at tunica??? in reply to Spotter, 12-12-2005 21:16:08
To bad you don't enforce those limits. In the long run it will just hurt your program by not enforcing the rules "you" post. When there is tractor more than obviously over RPM it should not take a protest to get it checked! Where is your officials? Run what you brung as hard and fast as you want!!
Rahlo
12-16-2005 02:48:58
 Re: rules at tunica??? in reply to To Bad, 12-14-2005 07:26:43
Spotter, I could tell this problem is hurting the Tunica pull. I think your increased hooks were up 20% or so this year from last. Some folks just need to complain. Load up and go home and stop whining.
