more power
luv620
12-10-2005 16:48:08
I have a 620 that the book saids should have 100 psi per cylinder, mine only has only 75 psi. It runs fine but I wanted to give it a little more power for pulling. I am going to put new rings in it, but I was wondering what else I could do to give it more power? Like LP pistons, or equivalent compression, and what can I do to the head?
Thanks in advance,
luv620
BushogPapa
12-11-2005 05:53:48
 Re: more power in reply to luv620, 12-10-2005 16:48:08
I have found that Matching the intake openings to the Head openings, and cleaning them up can make a difference...especially when you have a true "Multi-Angle" valve job done, with the valves re-shaped to a full contour, polished and the seats done the same to for a Venturi effect between the valve and seat... The Power at full rated RPM increases a great deal....and Lugging is about the same as original. So, Horsepower is Increased at rated RPM... If you have access to a valve grinder, you can do it yourself... I can walk you through it.. Ron..
buickanddeere
12-10-2005 17:44:17
If she will spin out in 1st gear. Spend you money on harder biting tires. There are several past posts here that a search will find about modest upgrades that add some serious HP to two cylinders.
CLIFF S
12-11-2005 04:50:15
 Re: more power in reply to buickanddeere, 12-10-2005 17:44:17
I agree with BuckandDeere the best place to start is from the bottom up, You can have too much POWER for Traction! So start with getting most of your power to the ground first!!
