super m piston kit
supermpullr
12-04-2005 18:09:46
i am going to rebuild my super m this winter to pull.what kind of piston kit should i get? want to get 4 1/8th bore. what would be better,steppped head or domed? Should i get a tisco kit,red power kit or good used oringal ih domed firecraters with new rings? looking to spend around $500-$600 on a kit.
Danny Hogge
12-05-2005 07:08:33
 Re: super m piston kit in reply to supermpullr, 12-04-2005 18:09:46
I have a good set of pistins 4 1/8 fire crater and sleeves. I took them from a good running 281. It was holding 160 lbs of compression with the 8060 and then changed to a lp head and went up to 220 lbs of compression.All you would need is a set of new rings . You can get them from NAPA. This tractor was very competitive in the 57,62 and 7200 lb weight classes in first gear. Tx, DR
supermpuller
12-04-2005 18:46:49
I have a set of firecraters for sale 4.125 email is open
