m pistons
reckless red
12-03-2005 15:12:09
7" stroke h rods what piston would work and what mods would i have to do to rods thanks
DANNY HOGGE
12-05-2005 07:28:15
 Re: m pistons in reply to reckless red, 12-03-2005 15:12:09
USE 427 CHEVROLET TRUCK HEAVY DUTY HIGH DECK .060 OVER.REMOVE SLEEVE AND BORE TO 4.310 WILL NEED TO MAKE A NEW WRIST PIN BUSHING TO ADAPT TO THE SMALLER DIAMETER PIN. YOU MAY NEED IT MADE EXCENTRIC TO ADJUST YOUR COMPRESSION RATIO. THIS WILL MAKE 409CID SAME AS DENNY SLALES . IF DONE RIGHT IT MAKES A GOOD RELIABLE ENGINE WITH NO WATER PROBLEMS AND AS DENNY SAYS IT WILL MAKE ABOUT 120 HORSE .YOU CAN USE YOUR M RODS . WILL REQUIRE A LOT OF MACHINE WORK TO RODS AND CAM AND BLOCK AND IT WILL NEED TO BE BALANCED WHEN ALL FITTING WORK IS DONE AND 7 INCHES WILL BE TIGHT BUT IT WILL FIT AND DO A GOOD JOB FOR A LONG TIME TX, DR
ChadS
12-04-2005 04:20:53
The old setup was to weld a Dodge or Chevy rod to the H rod, and use a 440 Dodge, or a Big block Chevy piston. Seen em hold, seen em break,,, But the problem I see is fitting that big H rod into the Chevy piston, and not have the H rod bottom out in the piston head,,, I imagine thats why they cut and paste the 2 rods toghether,,, Chad
