MM U puller piston and rod
savsmm
12-02-2005 06:59:09
I have a U. If I put a G crank in it and use M5 blocks, what piston and rods can I use and how do I have the crank ground? I think I got everything else figured out by reading this site, but don't know what piston/rod combo can be used. Thanks. Lewis
Mopower
12-05-2005 04:50:52
 Re: MM U puller piston and rod in reply to savsmm, 12-02-2005 06:59:09
Lewis, did you get my e-mail on this subject?
shawn W
12-03-2005 06:36:05
Hello
i got a set of new ross racing pistons on the shelf for that application and the rods and crank arent that hard to do. email me i have a shop that can do just what you are looking for
[email protected]
Shawn
dm
12-03-2005 05:31:16
Contact LW at wilson machine shop 910-673-3505,he has light wt pistons ,reground cams,and other parts.
ejr-IA.
12-02-2005 11:58:54
I think you grind the 403 crank to fit the U rod and buy custom pistons and over bore the M5 blocks.Everetts or Welters have the pistons.
MolineG
12-02-2005 14:33:52
 Re: MM U puller piston and rod in reply to ejr-IA., 12-02-2005 11:58:54
call kieth merfield, he can stroke the crank make welded custon rods and sell you the pistons.
price very good ph # 563-582-8710
