Valves in a 350 head
southpaw
12-01-2005 18:13:03
How big of valves can a guy put in a 350 Farmall Head and what are they out of. Also I thought about using pistons out of a 217 gas john deere 55 combine, with a 1" stroker, not sure if the pin is too big. Any thoughts on this...
ChadS
12-05-2005 08:31:02
 Re: Valves in a 350 head in reply to southpaw, 12-01-2005 18:13:03
Big valves wont do you much good on a 1 inch stroker, a good port and polish is bout all you need on the head. As for pistons, you need a compression height of 2 inches for a 1 inch, stock rod H motor. Ih 6 cyl pistons work well and you get a lot of bore sizes. If you build the pistons right, you can make a high domed piston, by putting them in the way the arrow is supposed to go,,, That puts the higher part of the firecrater directly in the chamber. A little machine work is required to fit,, but its no much at all, Chad
