WD-45 ENGINE
WCPULLER
11-30-2005 18:57:23
HEY I GOT A WD45 MOTOR IN MY WC I WAS WONDERING IF ALLIS-175 CRANK, SLEEVES,AND OISTONS AND CAM WILL WORK IN THE 45 MOTOR. I WANT TO TRY TO KEEP IT CHEAP. I STILL WANT TO PULL STOCK CLASSES WITH IT. I'M RUNNING 15.5BY 38 CUT TIRES. 3 GEAR 3,000 TO 3500 AND 1ST GEAR IN 4500 I WANT TO GET 2 OR 3 GEAR IN 45OO GOT ANY HINTS THANKS
Don't You Guys Know
12-01-2005 07:36:46
 Re: WD-45 ENGINE in reply to WCPULLER, 11-30-2005 18:57:23
You guys are kind of hard on this so called stock puller. Don't you know that this is the only way you can make a WC/WD/WD45/D17 competitive in the stock classes is to do these kind of alterations. If he works on it real hard he even might beat a stock H Farmall or B John Deere!!!
G/MAN
12-01-2005 07:17:46
You want to do all that to pull in stock classes? No wonder guys get hot under the collar.
Aaron SEIA
12-01-2005 05:09:20
The pistons would work just fine. The 175 was the same bore and stroke as the 45. The crank might with a lot of work, the 175 had larger diameter main journals, but they are both 4.5" stroke so you wouldn't gain much anyway. I've heard the 175 cam helps, but I have no idea what it takes to get it in the block. Not sure how stock a WC is with a WD 45 engine anyway. Why not stuff all the 45 and 175 parts into the WC block? They all fit same as the 45.
Aaron SEIA
WCPULLER
12-01-2005 18:49:41
 Re: WD-45 ENGINE in reply to Aaron SEIA, 12-01-2005 05:09:20
WOULD THE HEAD OFF A 175 MAKE IT HAVE MORE POWER ALSO OR A D-17 BETTER?
TS
12-01-2005 04:25:49
In my neck of the wood's you wont pull it in a stock class wntil you put the stock block back in it and go back to your 12.4 28 tires, It sound like it should go to the modified class where it belongs and leave the stock as they get tractors alone!!!!!
WCPULLER
12-01-2005 17:49:12
 Re: WD-45 ENGINE in reply to TS, 12-01-2005 04:25:49
WE ONLY HAVE ANTIQ. AND STOCK WE DONT GO BY DIV. STOCK IS ANYTHING GOES
