Chad s m?
SUPER MTA PULLE
11-30-2005 10:27:14
A while back you told someone he could buy rings for the sleeve counterbore for 281.Where do you get them and price? Also will yur copper haed gaskets work with this setup?Reliably?Lastly with high comp. pistons and 400 head how much compression and hp will a 030. copper gain over composition one.Evfrything stock for a baseline.M block no sleeve.Any other pullers comments appreciated thanks.
ChadS
11-30-2005 10:41:53
 Re: Chad s m? in reply to SUPER MTA PULLER, 11-30-2005 10:27:14
Wilson machine, Gary Baker, maybe, Paul Marlatt,,, The copper head gasket will work without the rings, or with them, as long as the block has been machined with the rings to make it flat for it to seal up. As long as you have the clearence on the pistons and the head, you can pick up 5hp from the compression increase. Stock is around .072 thick compressed,,, Probably around 10-15 psi more with a 30,, a 450 gasket will seal up a M block, without the rings, you can mill the head down a bit and pick up from where the groove leaves behind, but the rings would be helpful in keeping the compression pressure up. Gotta be milled flat to use copper,,,,, if not, it will leak water in the oil,, will seal the cyl,,, but not anywhere else. Chad
b barenie
11-30-2005 17:13:03
 Re: Chad s m? in reply to ChadS, 11-30-2005 10:41:53
smta
GARY BAKER'S PHONE # 734-678-9688
With a few measurements, he can make the rings for you !
If you have high compression pistons, why fool with a copper head gasket ! Head to piston tollerance gets real tricky at 30thds. Thats about a two head gasket process !
