firecrater pistons, 560.
jpl
11-29-2005 17:53:47
do they make the firecrater pistons for 560 gas and can it be bored larger or use thinner sleeves or no sleeves. lp head maybe? thanks for all the help.
ejr-IA
11-30-2005 17:51:04
 Re: firecrater pistons, 560. in reply to jpl, 11-29-2005 17:53:47
tlib-ulav has the 301 piston for 275.00 std. 40,60 over.
ChadS
12-02-2005 06:02:12
 Re: firecrater pistons, 560. in reply to ejr-IA, 11-30-2005 17:51:04
That must be a dirty word,,,, LOL!!! ChadS
jpl
11-30-2005 11:43:03
thanks chads, thats what ill do, run sleeveless with 301 pistons, local machine shop says he can redo my head, port it and clean up around the valves. but they not sure about bigger valves yet. was wanting more compression but will be happy just getting it running good. if its not set up for good weight transfer extra horses arent going to help much anyway, just want to have some fun pulling but dont want to be last either.
Gritty
11-30-2005 00:49:01
On my 560 I used the 3 3/4 overbore kit with the high altitude pistons.They had a nice dome on them.I also used the head off of a 301c.i that I robbed off an 806.Some I.H truck heads can be used.E-mail is open.Eric
jpl
11-30-2005 06:12:10
 Re: firecrater pistons, 560. in reply to Gritty, 11-30-2005 00:49:01
thanks for reply gritty, i"ll check the local int dealer see what they have. glad to hear i can go 3 3/4 pistons. was gonna trade my 300 row crop for 301 but the 301 was junk. still looking though.
ChadS
11-30-2005 08:11:45
 Re: firecrater pistons, 560. in reply to jpl, 11-30-2005 06:12:10
You would have more $$ in making a 291 than just going big and build a 301,,, The piston kits are more expencive for the 291 than the 301. 301 bore is 3-13/16 and all you have to do is bore the block and buy pistons. No sleeves. Look for the best price on 301 kits. Napa has em for 80 bucks a hole,,, but can be bought much cheaper. Truck heads are the ultimate setup, but you can port and polish the tractor head and get close to the truck head. The truck heads are a high compression head, like the LP heads of the Letter series IH tractors. Good for about 20 hp. JMHO,ChadS
