Cylinder head swap, yey or ney?
Mperfection
11-27-2005 18:04:26
I percentage pull an M and have recently aquired a complete 400 motor that trashed the crank. Is it worth my time to swap some parts over or just save my money and do the 400 motor later?
Mopower
11-29-2005 10:00:01
 Re: Cylinder head swap, yey or ney? in reply to Mperfection, 11-27-2005 18:04:26
Hey Chad, did you see the pic of AC's new M-M project?
ChadS
11-29-2005 13:57:21
 Re: Cylinder head swap, yey or ney? in reply to Mopower, 11-29-2005 10:00:01
No not yet. Did he sell the H? Chad
AC
11-29-2005 14:47:09
 Re: Cylinder head swap, yey or ney? in reply to ChadS, 11-29-2005 13:57:21
heck no...its still there in parts and pieces and piles.....just looking at other posibilities...Does not matter what I build out of that ZB, the H will still be capable of beating it...
Mopower
11-30-2005 04:09:03
 Re: Cylinder head swap, yey or ney? in reply to AC, 11-29-2005 14:47:09
Yeah unless you get that 433 cube small block MM that I know is possible. Uh oh, grab a tube of preparation "H".
ChadS
11-30-2005 09:34:44
 Re: Cylinder head swap, yey or ney? in reply to Mopower, 11-30-2005 04:09:03
Some one should come git that ZAU I got and show it towards the light,,,,, Sure would be a nice one! Chad
Mopower
11-30-2005 09:57:37
 Re: Cylinder head swap, yey or ney? in reply to ChadS, 11-30-2005 09:34:44
Tell Andy he NEEDS it. His ZB is basically a rear end...we had to return the worthless junk front end to the salvage yard as part of the deal. Poor old girl. What's going on in your neck of the woods?
ChadS
11-30-2005 10:26:57
 Re: Cylinder head swap, yey or ney? in reply to Mopower, 11-30-2005 09:57:37
Winter stuff,,, More insulation in the shop, antifreeze in the engines, putting stuff away till spring. Been working on a 69 Maverick for the past few months. Nice ol car,,, Its getting the V8 treatment, face lift. Other than what I mentioned, and the honey do list,,, not a whole lot,,,, Andy knows I got that ZAU,, But from what I understand, he is going in the right direction,,, start with a part, and build on to it as he goes. Thats How I built My H,,, of course, its apart again,,, so The parts hunt continues,,, I have been watching alot of Dukes of Hazzard lately,,, driving the wife crazy with the dixie horn from the ol General HAHAHAHA!!! Oh,, There is a guy from Illinois that has alot of Molines that he buys sells and trades,, I cant remember what the name is,, but was out his way a few years back,, parts everywhere! Chad
Mopower
11-30-2005 11:51:45
 Re: Cylinder head swap, yey or ney? in reply to ChadS, 11-30-2005 10:26:57
Greg Herriott, John Grandfield, or Kevin Moschenrose?
ChadS
12-02-2005 05:56:14
 Re: Cylinder head swap, yey or ney? in reply to Mopower, 11-30-2005 11:51:45
he is from Rantoul Ill, all I can remember,,, ChadS
Mopower
12-02-2005 06:00:26
 Re: Cylinder head swap, yey or ney? in reply to ChadS, 12-02-2005 05:56:14
Oh ok. I have M-M connections all over. Sometimes I loose track. Greg Heriott builds MMs over in Ill somewhere. Nice fella. I watched Gary run his M at Wauseon...WOW. Adam Coleman was not too shabby either in his "half baked" M.
ChadS
11-28-2005 06:58:35
Depends on how far you want to tear the M engine down. Everything will interchange, except the sleeve and pistons,,, the M block is a smaller casted block in the cyls, VS the newer style blocks. But, the head, cam, rods will swap out, use the M rod bearings with the 400 rods, If you pull the engine out of the frame, if you have the clutch and flywheel from the 400, you can use that in the M, just use a SM clutch disk to keep the M input shaft spline. That gives you a larger clutch, and a heavier flywheel. You can put the M crank in the 400 block, use the M bearings and rear main seal from the M, the 400 seal is bigger in diameter,,, You can put the 4-1/8th bore pistons in the M, run no sleeves, and buy a set of those rings that fill in the sleeve flange gap. Or, run with out the flange rings, use a 450 head gasket. the 450 gasket will seal it up. If you got a good M short block, Id swap out the cam and head, flywheel and clutch, if you have it and feel ambitious,, You would pick up some good torque with that set up from the M engine. Hope this helps, Chad
