H/300 Head Question
HeavyD
11-27-2005 15:56:36
I have a head from a 300 and want to put it on my H. I have allready bought the stepped head piston kit for the H. The question is, The tube that goes across the top of the rockers from one end of the head to the other, ( I think its called the breather tube ) how do you hook it up on the 300 head? It has only one tube coming up out of the front of the head. Were do you hook the breather tube from the H air cleaner to on the 300 head? Thanks in advance,
HeavyD
JonM
11-27-2005 16:11:44
 Re: H/300 Head Question in reply to HeavyD, 11-27-2005 15:56:36
I put a newer head on my M, the new head had a short piece of pipe threaded into it and angled up towards the valve cover, for the aircleaner, I drilled a hole in the valve cover and welded a piece of tubing and used a rubber hose to connect the two together,hope this helps.
JonM
