jd d flywheel on a g
rob patton
11-26-2005 17:41:59
woundering why people put d flywheels on g's and do they have to do any fabrication to the splines on the crank to fit thanks
G/MAN
11-27-2005 11:41:22
 Re: jd d flywheel on a g in reply to rob patton, 11-26-2005 17:41:59
Where have you seen that done? I don't see much advantage. Yes, a "D" flywheel is heavier and has more intertia once moving, but it's also harder to GET it moving and takes more power to KEEP it moving. There's no such thing as a free lunch, be it a heavier flywheel, electric-fan "supercharger" in the intake, or super-duper governor that can't open the carburetor any farther than the stock unit.
Iron stuff
11-27-2005 11:21:54
d flywheel is heavier,hence more rotating mass. not sure on the fit.
