jd a manifold
jd plowboy
11-26-2005 17:14:56
have to put a exhaust manifold on my a. it is a 1950 all fuel. wanting to know whether i can put a gas or a lp manifold on to get more horsepower or should i go back with the all fuel one. what would i have to change to make other ones work.
which setup would be best on a stock tractor.
thanks for your advise
jd plowboy
11-27-2005 14:41:33
 Re: jd a manifold in reply to jd plowboy, 11-26-2005 17:14:56
if in the future i want to get more hp what do you recommend. should i change the carb also. it is stock now(i think).also do you know where i can get 9 bolt wheels (14x38) and hubs.
Mike n Mo
11-26-2005 18:29:25
It should be a bolt-on swap to put a cold manifold on your A. If you are buying one get a cold (gas) manifold. It should be worth a couple of HP, but don't expect miracles. The only thing to watch for is the angle of the bolts on the exhaust pipe flange, some are horizontal, some are at a 45* angle. Mike
jd plowboy
11-27-2005 09:26:18
 Re: jd a manifold in reply to Mike n Mo, 11-26-2005 18:29:25
thanks mike. where can i find one of these manifolds. is it different than a regular gas manifold.
G/MAN
11-27-2005 13:17:00
 Re: jd a manifold in reply to jd plowboy, 11-27-2005 09:26:18
There are many sources for "cold" manifolds. Several companies made them back in the day - Heisler, Johnson, etc. and of course JD built gasoline "A"s that had a different manifold than the all-fuel tractor. There are reproductions being made today and sold by various companies. Probably right here at YT, for that matter. A couple HP is probably all you'll see, as was mentioned, because the carburetor and fuel-air mix will be kept cooler.
