looking for used power block piston
ROB HARTMAN
11-25-2005 12:48:25
Hello, I'm looking for a used 720/730 John Deere gas standard 6" bore piston to fix a skirt on my 6" power block piston for my 1941 'A'. Or if somebody knows where I could get a single or a set of original power block piston's. I don't want to bore it any bigger because I don't have the money to stroke it. Any help would be greatly appreciated. Thanks, Rob
JDGnut
11-26-2005 21:01:16
 Re: looking for used power block piston in reply to ROB HARTMAN, 11-25-2005 12:48:25
You might need to check the piston pin size on the 720/730 pistons.. I believe they are bigger... Not a big deal to make the rods.. Just an added cost.. (the M&W pistons are probably ligher..) Good Luck
JDGnut
730-LP
11-25-2005 20:06:56
I have a good set if intrested e-mail me your ph# and I,ll call you
