METHANOL
JOHN DOE
03-12-2002 11:04:18
Works great.Hard to hide the smell.
oldtimer
03-13-2002 20:30:50
 Re: METHANOL in reply to JOHN DOE, 03-12-2002 11:04:18
Any of you guys heard of ETHANOL???? Made from corn,actually it's corn whiskey, up here in Minn all of our gasoline is a blend of 10% Car manufacturers sell flex fuel cars now that burn 80% ethanol,point is if you pull with pump gas you get 10% ethanol.Helps them farmers and have fun too.Raises the octane,reset timing ,more umph.
BOB
03-13-2002 12:26:33
how can I get some can you run it in a stock tractor if so how would you mix it how much HP will it give you . Thanks
Brad
03-14-2002 05:20:00
 Re: Re: METHANOL in reply to BOB, 03-13-2002 12:26:33
it will give you no gain in the hp column, but it will add torque
cd
03-13-2002 13:00:51
VP racing fuels has it I know
cd
03-12-2002 16:31:01
what does it take to burn it any mixes or anything or pure
JAILBIRD
03-13-2002 12:14:01
 Re: Re: METHANOL in reply to cd, 03-12-2002 16:31:01
COMPRESSION.
YOU CAN MIX 25-50% WITH RACING FUEL OR STRAIGHT.IT TAKES ALOT OF COMPRESSION TO GO STRAIGHT.IT BURNS COOLER THAN GAS.SMELL IS NOT BAD IF MIXED.IT TAKES ALOT MORE FUELING FOR IT.
Fuel Frank
03-13-2002 18:16:27
 Re: Re: Re: METHANOL in reply to JAILBIRD, 03-13-2002 12:14:01
Old rule of thumb when running alcohol,It takes about twice as much fuel compared to 89-100 octane
gas. Also helps to bump up the compression when running alcohol.
03-12-2002 14:39:08
it worked in my JD A
it worked in Tilley's 88, too
03-12-2002 16:59:33
 Re: Re: METHANOL in reply to ??, 03-12-2002 14:39:08
DON'T BE MAD BECAUSE TILLEY KICKED YOUR A_ _ !!!
03-12-2002 18:08:58
 Re: Re: Re: METHANOL in reply to it worked in Tilley's 88, too, 03-12-2002 16:59:33
HA! HA!
