460 power steering
TWL
11-23-2005 15:09:10
Have any of you put a car power steering pump to run the power steering.Would greatly appreciate any help.
ChadS
11-25-2005 07:48:26
 Re: 460 power steering in reply to TWL, 11-23-2005 15:09:10
I used a Ford pump, but Im running the new style IH power steering setup like what is used on the 706,806,,,etc etc,,, Fully hydrostatic,, The ford pump runs it well stock, I stepped up the pressure relief spring pressure to give it more line pressure and sped up the steering speed. The ford pump is pretty easy to make brackets for, you got 3 bolts with tabs spaced out well. ChadS
TWL
11-25-2005 11:31:47
 Re: 460 power steering in reply to ChadS, 11-25-2005 07:48:26
I appreciate the help.Thanks again
