rpm check
mshadow
11-22-2005 17:15:56
I have a stupid question? I don't know that much about deisel engines. At pulls I see the gas engines have a plug wire available so the rpm's can be checked. How are the deisel engine rpm's checked at pulls?
G/MAN
11-23-2005 07:34:13
 Re: rpm check in reply to mshadow, 11-22-2005 17:15:56
As 856 said, a hand-held tach can be used - either of the "photo" or direct-reading variety. You can also read off the PTO shaft if you know its speed at high idle for the engine - that data is avaiable for most tractors. And there are tachs with a pickup that sense injection pulses off an injection line, but you don't see many of those.
856 puller
11-22-2005 18:28:51
in our club the tractor has to have reflective tape on the balencer or flywheel and is checked with a hand held tach
