WC or WD45
TommySC
11-21-2005 08:14:05
Our club rules are 1st gear and 10% over RPM for stock antique ,looking to build a tractor for 4000 lbs and under.
Is a WC allis with a WD45 crankshaft better than a wd45 build stock to pull under these rules
Dave in MN
11-23-2005 17:55:28
 Re: WC or WD45 in reply to TommySC, 11-21-2005 08:14:05
A friend of mine has pulled both models. WC is a little lighter, you can use same basic motor in either tractor, older model WC's didn't have starter, and they had hand brakes (not very handy). He likes his WD's alot better.
Ripples
11-21-2005 11:44:06
WD with D-17 motor or a WD45 with same works well, I don't think the WD is that much heavier than a WC especially if your aiming for 4000#. My WD is 3240 by itself.
Doug Boll
11-21-2005 11:15:43
I like the unstyled look for pulling, the wc wouldn't have the hand clutch ect. so the wc should be lighter and later parts fit. I'd build a wc if I was an AC man.
Farmall Daddy
11-21-2005 16:02:49
 Re: WC or WD45 in reply to Doug Boll, 11-21-2005 11:15:43
I have a 1942 military WC that I pull with. The motor is a 4 1/8"X 4" stroke and is around 40h.p. My WC weighs in at 3260 with me on the tractor. I pull the 3600 pound class, and this past year, I wasn't out of the top three unless I had motor problems. Very competitive, plus I still have the ability to use it on farm jobs and not have any problems. While we are on the topic, does anybody know if you can put the 4 1/8" flat top pistons into a WD block and run a 4 1/2" WD-45 crankshaft? I have been told I can do this, but I would like to have further advice. Thanks guys!!
new kid in town
11-21-2005 19:22:44
 Re: WC or WD45 in reply to Farmall Daddy, 11-21-2005 16:02:49
yes you can. might take better fuel. watch your timing and don"t lug it.
