single front on M or H
joecool
11-20-2005 05:55:26
Is a single front tire on M or H a weight savings? or are they worth anything? I know of one going to be in a estate auction this week. would like to know what it is worth. complete M.
Dub J
11-20-2005 11:55:02
 Re: single front on M or H in reply to joecool, 11-20-2005 05:55:26
Changed from a double to single on our M. There was a about a fifty pound difference. Plus if your front end is loose, it will drive better on the road.
JJ
ChadS
11-20-2005 08:13:25
It would be a good saving, if you did not use the original cast rim. Those are solid cast iron, and weigh alomst as much as both wheels. Its easy to adapt a pressed steel wheel to it, just have to make a new axle, or hub to fit. Id pick it up anyways if it goes cheap, in stock form they go for good money to restorers, they raise the front end up quite a bit if the stock wheel is used, it sits higher,,, Hope this helps, Chad
