John Deere G Power
GO DEERE
11-19-2005 19:05:29
I have a '51 G with a 6.5 bore x 7.5 stroke, msd ignition, johnson manifold, ported head with big valves. Approximately, how much power will this tractor have?
GO DEERE
11-19-2005 19:28:18
 Re: John Deere G Power in reply to GO DEERE, 11-19-2005 19:05:29
Aluminum pistons. Will have a cam out of a 720.
G/MAN
11-23-2005 07:38:27
 Re: John Deere G Power in reply to GO DEERE, 11-19-2005 19:28:18
Piston material doesn't mean anything. The compression-ratio does. A stock "G" in good tune is good for about 40 horsepower give or take. One with hi-comp pistons and a good cold manifold 50-55. With a Power-Block, they were supposed to make closer to 60. Yours "should" be good for 75 easy, I would think. I say "should" because it's not just a matter of throwing the "big" parts at it, it's a matter of getting everything to work together properly and proper tuning. I'd be looking into one of the "performance" cam grinds available from Robert's, etc. instead of a stock 720 camshaft. After all, a 720 is SMALLER than a stock "G", and you've got a bunch more cubes than a stock "G" there.
