How much to bore JD A
johndear
11-16-2005 20:08:07
Is it feasable to bore / sleeve a stock JD late A block for 6.125 pistons? Would a stepped sleeve about .25" wall work (step at top to hold it in block)?
Thanks,
JDTH
11-18-2005 03:47:39
 Re: How much to bore JD A in reply to johndear, 11-16-2005 20:08:07
I'm in the same situation you are in only with a mid A. I have a stock block needing sleeves and a Power Block also needing sleeves. I would rather put big sleeves in the stock block, for rule issues, than in the power block. How big will live and who to have do the work to make it live?
Drew
11-17-2005 20:11:10
As Ironman stated, there are A blocks running 6.750" bore. If all you want is 6.125", you could pay $1000 for a 6-3 and come out money ahead and unless someone let it sit in a hot tank, you know it will hold water when its all said and done.
If you sleeve your stock block, I wouldnt stop anywhere near 6.125, because it doesnt cost that much more to go BIG! And make d@mn sure that the sleeves are fastend in so they cant come out the back instead being pressed in and smeared w/ windshield goo and praying they dont come out. I know of several press job w/ windshield goo blocks that became hand grenades. BUYER BEWARE!!
johndear
11-17-2005 20:59:11
 Re: How much to bore JD A in reply to Drew, 11-17-2005 20:11:10
I am sure a powerblock would be the most simple, however, no JD part number on it. If I bore and sleeve my own block at least I will know what I have. Any idea of a sleeve for a 6.125 or 6.75 bore with a flanged end?
Ironman
11-16-2005 21:08:32
I think they can bore and sleeve JD A blocks out to around 6.75", so it's definitely possible. 6.125" should be reliable, but there are many out there running bigger than that.
