TRACK CONDITION
TROUBLED
11-14-2005 14:23:28
WHICH WOULD WORK BEST FOR INDOOR TRACK PACKED HARD ON TOP BUT VERY SOFT UNDERNEATH. 13.6-38 OR 16.9-30. ANY THOUGHTS
Lamont
11-14-2005 17:29:21
 Re: TRACK CONDITION in reply to TROUBLED, 11-14-2005 14:23:28
If you're not under 4000 lb., I'd go with the 16.9 x 30. It has a pretty good rolling circumference and flat plate. It's not an extremely short/wide tire so I would think it should hook up good. Under 4000 lb., I'd pick the 13.6 x 38 to keep the ground pressure up. My $0.02.
Dave in MN
11-14-2005 16:23:25
It will matter alot how heavy a tractor you will be pulling. I have a hard time to get short, wider tires on a tractor under 5000# to hook up. Good luck.
