IH d282 stroke
jts
11-13-2005 05:20:09
how far can you stroke this motor and yous stock rods and pistons can you get a 1 inch
ChadS
11-13-2005 10:04:32
 Re: IH d282 stroke in reply to jts, 11-13-2005 05:20:09
Im not sure,,, Its tight in there now with the stock rods,,, Look for a set of rods that have offset rod caps and that will give some more room to swing,,, If its a diesil, are you running a charger on it? Chad
jts
11-13-2005 11:54:21
 Re: IH d282 stroke in reply to ChadS, 11-13-2005 10:04:32
chad its going to be natraily asperated
ChadS
11-13-2005 12:02:45
 Re: IH d282 stroke in reply to jts, 11-13-2005 11:54:21
Id say you could put a 3/8 total stroker in it and not have to do too much clearance work,,, Your compression will be alot higher if you do not recut the pistons to match the compression height for the new stroke,,, What I seen as the problem with going over that with stock rods are the nuts hitting the side of the block hard,,, maybe have the rod bolts inverted, redrilled and tapped so they thread into the rod instead of having the nuts,, that would give you a little more room to go more stroke. Chad
