Massey 44 RPM
Kevin
11-12-2005 19:35:43
Were will a massey harris 44 most likely run best with rpm? 1650 or 1800? Thes are the div II and div IV specs. Its got a dennys carb and reground cam and i dont know were its at with rpm right now, but think i should leave it alone? or order a tach and crank it up?
jerry l
11-14-2005 18:11:31
 Re: Massey 44 RPM in reply to Kevin, 11-12-2005 19:35:43
just was wandering what did you do to your gov. is there much adjustment with them???
Kevin
11-15-2005 13:39:38
 Re: Massey 44 RPM in reply to jerry l, 11-14-2005 18:11:31
Actually i was just about to make a topic to see if any one knows how to get the governer to allow more rpm in a massey harris 44.
unknown puller
11-13-2005 07:25:35
Get a tach and see where its at. If your pulling in div 2 have it set for div 2 and the same for div 4. After all it is just antiques you know!
