Need to fix my tires
Kevin
11-09-2005 17:28:57
The person i bought my tractor off of was shaving the back of the lug off the tires with a utility knife. Now no one has really complained about this yet but one of my friends was joking around with me that he was going to point it out at the meeting that my tires are altered so i cant run. Is there any way to fix my tires or am i better off leaving them as is without altering them anymore and hoping for the best?
Ohio M Puller
11-10-2005 08:39:02
 Re: Need to fix my tires in reply to Kevin, 11-09-2005 17:28:57
What I have found works well is a Heavy grit rotory sander, then use a butain torch on the lugs. Once their hot move the flame from the lug and rub the lug down word with a welding glove. Will make all your marks in the same direction as if they were road worn. Just my two cents.
Ohio M Puller
BAD A$$ SUPER M
11-09-2005 18:31:44
USE A HAND HELD WOOD PLANER
Jerry Cent. Mi.
11-10-2005 10:21:59
 Re: Need to fix my tires in reply to BAD A$$ SUPER M, 11-09-2005 18:31:44
A right angle ginder with an 80 grit flap disc will remove a lot of rubber in a hurry. TSC carrys the disc's.
