loose sleeve
john rennie
11-03-2005 21:29:26
How would you deal with a loose [new] sleeve on a farmall super h?
jd b puller
11-10-2005 20:33:16
 Re: loose sleeve in reply to john rennie, 11-03-2005 21:29:26
Did you do it yourself or did a shop do it? If you had it built, call the guy who did it and see how he's going to fix it. If you did it, listen to the other guys.
showcrop
11-06-2005 18:05:31
I had a loose sleeve on my Ford. I got a lock tight product called sleeve sealer or something like that and it worked well. good luck, colin
MagMan
11-06-2005 04:29:03
Napa sells sleeve set or something similar. Not sure what it is but I used lock tight. JON
Gamitch
11-08-2005 05:05:38
 Re: loose sleeve in reply to MagMan, 11-06-2005 04:29:03
I smear a little fine grain valve grinding compound on em and drive em in.
