taylor dyno spanner
showcrop
11-03-2005 18:11:17
I have a taylor dynomometer that needs re packing .I cant break the packing nuts loose. They are shaped like square cut gears and are approx. threeinches in diameter. I contacted Taylor, and they told me what to get and where. but after I got it itwouldn't go onto the nut can you tell me where to get this spanner?
LW
11-04-2005 06:03:25
 Re: taylor dyno spanner in reply to showcrop, 11-03-2005 18:11:17
If the wrench you got is not big enough get the next size bigger you can use a hammer and chisel, But it will leave a mark. You have a really good dyno, it will be worth the effort.
Trkr
11-04-2005 19:38:10
 Re: taylor dyno spanner in reply to LW, 11-04-2005 06:03:25
My dyno has the case eagle on its face,is it a Taylor?I think mine was made in Milwakee.
LW
11-05-2005 07:01:05
 Re: taylor dyno spanner in reply to Trkr, 11-04-2005 19:38:10
Is it a water brake? If so more than likely its a Taylor. I know they made dyno's for IH and Case.
Trkr
11-05-2005 16:02:27
 Re: taylor dyno spanner in reply to LW, 11-05-2005 07:01:05
Yes ,you have to hook a garden hose to it,and its a pull type on a small trailer.
LW
11-05-2005 17:49:09
 Re: taylor dyno spanner in reply to Trkr, 11-05-2005 16:02:27
The Hydraulic ones have a water hose hook up for cooling, Look inside if it looks like a impeller pump with the outer housing having a arm that pushes on a button hyd. cylinder its a water brake.
Trkr
11-07-2005 18:07:03
 Re: taylor dyno spanner in reply to LW, 11-05-2005 17:49:09
Thats exactly how it works,is it worth keeping?
LW
11-08-2005 18:16:33
 Re: taylor dyno spanner in reply to Trkr, 11-07-2005 18:07:03
If you need a dyno it is, if not sell it!
Trkr
11-09-2005 11:29:57
 Re: taylor dyno spanner in reply to LW, 11-08-2005 18:16:33
I could sell it but I dont know what its worth.
LW
11-04-2005 06:03:07
