New Motor Break In Chad Or Others
MagMan
11-03-2005 17:09:00
Well I finally got the H motor I was buiding running this week. OK How do I break this in for the first pull in the spring remember we will have snow here in a few weeks. All new Bearings including Cam, New Firecrator Type Pistons aftermarket. C169 Cam,Head shaved 60 thousands, Head also had intakes opened up a little, C169 intake, SM carb,. Give me your take on break in boys. JON
BushogPapa
11-05-2005 06:35:59
 Re: New Motor Break In Chad Or Others in reply to MagMan, 11-03-2005 17:09:00
You need to put a fairly good load on the engine within 20 minutes of running to seat the rings... Otherwise, the cylinders will be glazed and the rings wont seat-in after that happens... Not a "Full load"..just a good load like pulling a drag or disc in one gear lower than it actually could pull it.. It only takes a few minutes..won't need to be over 1/2 hour to seat the rings....the Main Bearings take a lot longer to seat-in than the rings.. Approach full RPM cautiously at first, as the Mains may tighten up if they are not broken-in enough.. I like to run Fully Overhauled engines for 20 "Engine Hours" before I feel they are ready for a real hard workout..
Ron..
ChadS
11-04-2005 09:43:56
I would not idle it for long periods of time while new. I throw em on the dyno and run them with a light load for a few hours. Working the engine helps everything warm up and seal much better vs just running it. Yeah, you could take the H for a drive, put about 30 miles on it. You get 2 benefits, a long running time with a light laod on the engine, and your tires get a little sharper! Change the oil. I change them every 2-3 hours till I get about 10 hours on the motor, change the filter and change at regular intervals. The first time you get it warmed up, retorque the head, and do it in steps, they will loosen up a bit and you could chance leaking inbetween the cyls. Dont try and tune it for power until you put a good 10 hours on it. The reason is, so many factors change thru out the break in process, youll chase ghosts in power output, it will gain power, then lose it, gain it lose it, etc etc, most of the time, its the rings not seating in,and creates uneven cyl pressures. Take it for a drive, 5 miles a night till you get about 10 hours on it, run it bout 1/2 throttle then gradually work your way up to full throttle on about the 3rd cruise. Ride the brakes a little too, just a few seconds to work it. After that, then you can start adjusting the carb, jetting, timing, etc etc for max power. Thats how Id do it if I did not use a dyno to break em in. ChadS
MagMan
11-04-2005 11:34:35
 Re: New Motor Break In Chad Or Others in reply to ChadS, 11-04-2005 09:43:56
Thanks Chad I dont have acess to a dino. At this point I am looking for a smaller carb and I only have one rear tire . So It looks like its going to have to set I did run her at 1/4 to 3/4 throttle today for about 15 mins up and down to get her half way warm I have a few water leaks At the hoses and pump and I tryed to adjust the carb but The SM carb I turned the main jet all the way in and she still runs a little smokey. So I either need to go to an H carb or a SH or 300. So untill I can find another used tire or something she will be sitting. If it sits through the winter should I fog it? Thanks to everyone on there break ins it means alot for your imput. JON
ChadS
11-04-2005 11:59:47
 Re: New Motor Break In Chad Or Others in reply to MagMan, 11-04-2005 11:34:35
On the carb you have, (SM) Is the idle mix screw in the carb flange instead of the lower postion like the M has? Id say a #27-29 venturi would do you justice, for max low end torque use a 25 which is from a M. The new style carbs that have the idle screw in the carb flange are tricky,,, somewhere, they create an internal leak and make the whole carb act up, smokes from running rich. Ive tried fixing these style carbs, from new adjustment screw, throttle shafts, cleaned it a 100 times,, no matter what, it never got better! So I have always used the older version of the Marvel Shebler used on the M thru early SM. Just had better luck with the older carbs,,,, Some have said to run it in at rpm intervals,,, like 1/2 throttle for 20 mins, 3/4 for another 15, and full throttle for 25 minutes with no load on the engine. Excessive idling is a no no in my book, the rings dont seat in. Higher rpms over idling, gets the parts moving, and warms up, and seals up. at low rpms, the shavings the come from the rings will stay put and cause damage, at higher rpms, it makes a finer shaving, and blow out the exhaust, or wash down into the oil into the oil pan, then into the filter to be collected. thats why I say keep the oil changed for the first few hours of operation to keep it as clean as you can. What are you gonna do when you can pull a 2-16 plow in heavy soil in 2nd and 3rd gear?? It could,,,,, ChadS
MagMan
11-05-2005 09:35:45
 Re: New Motor Break In Chad Or Others in reply to ChadS, 11-04-2005 11:59:47
Well it sounds like I need to check these carbs out better. And stop running her untill I can get her hooked to something.The 2 16s I have now get pulled by the M at an idle in 3rd gear usally. lol I will see what I can find. JON
buickanddeere
11-04-2005 06:21:55
Mother Deere sells a fine break-in oil.
skip 33652
11-03-2005 22:41:43
the best way to break in any engine starts before engine is is started for first time.make sure all internal parts are lubed up use lightweight( i prefer 10 weight and use 10-30 in my pulling tractors) non detergent or breakin oil. set carb and ignition timing so it will start right off no excesive cranking or fuel to wash rings and cylinders down.as soon as oil pressure comes up go to about half to two thirds governed engine speed ( this will help all splash lubed parts get oil mainly camshaft)set carb settings to get clean snappy response set timing with light. next get it on a dyno or other light load.once operating temp has come up increase load. some short full power loads would be nice within an hour or so of fireup.some things to avoid at all costs idling for extende periods. willnot let rings seat also does not get lubed properly, thick or heavy weight oil will not get into new or tighter clearances.overheating, breaking in rings on overheated cylinder bores will likly extend breakin time or will glaze things up so they never will . depending on how clean engine was on assebly how much assembly grease was used an oil and filter change at half hour and 10 hours would not be to much.a half thimble of foreign material and a table spoon of assembly grease will plug an oil filter twice over. Paul
jd b puller
11-03-2005 18:57:53
Make sure all is sound, change the oil and work the snot out of it.
SMP
11-03-2005 19:10:46
 Re: New Motor Break In Chad Or Others in reply to jd b puller, 11-03-2005 18:57:53
Thats what they told me warm it up good and pull the p#ss out of it, cool motor off before turning it off.
JD hauler
11-03-2005 18:50:28
I would do a good bit of idle time, then some mild load tests, hope it dont have new brakes yet. then a few miles of country cruising, I really believe that just letting the engine kinda cut itself in is the best approach, these puller engines spend most of there time idling at pulls, tune it to run perfect on fuel, not set to blow black smoke or run rich, this just washes oil off the upper end parts and dilutes the oil with carbon, hopefully you have electronic ignition on this ride unless you are from the stone age, if not get it, eliminate points and get a hot box msd , pro comp etc, you will be much more happier with your tractor, especially on those damp day starts, hope this helps, oh yeah, change oil and filters after about an hour on the fresh motor, this lets you rinse out any imperfections or grit that may have gotten in there from gaskets, sealers or whatever, good luck
