IH heads
es
10-29-2005 12:29:56
whats abetter head 301 gas head or 240 truck head will truck head bolt on to the 301 block
ChadS
10-30-2005 10:05:16
 Re: IH heads in reply to es, 10-29-2005 12:29:56
The truck head is great for high rpm. It will bolt right on, but you will need the entire valve train from the truck engine and the valve cover. The rocker arms are shorter on the truck. You have to watch piston to valve clearance on these heads. You could still use the firecraters if that is what you have,, you may have to mill off .100 off the domes of the pistons to give it some room. The truck head is a high compression head, like the LP heads to the M"s and H"s. If you need a photo of a truck head, I have a few to show. Hope this helps, ChadS
HB1967
10-31-2005 05:30:30
 Re: IH heads in reply to ChadS, 10-30-2005 10:05:16
Hey Chad, how about emailing me outside the forum. I have some questions about stuff you have for sale. Do you have any engines or short blocks for sale? Thanks
REDWHEELS
10-30-2005 19:39:12
Show a photo of a truck head and a tractor head valve recess area if you have some. I have a truck head and the valves are recessed alot too.
