Waukesha 310 or 283 stroking
neverwin
10-25-2005 21:53:55
1.Can anyone tell me if you can stroke a 310 waukesha to 5.5 inches using a 2.00 inch 77 rod without running into problems with the pressure lubed crank.
2. What about a 283 crankshaft stroked to 5.5"?
3. Will a 310 crankshaft fit into a 283 block?
b barenie
10-28-2005 15:13:11
 Re: Waukesha 310 or 283 stroking in reply to neverwin, 10-25-2005 21:53:55
call brad maybock in Ohio, he will tell you what you need to know !
And or e=mial me at [email protected]
Cody
10-26-2005 09:33:29
You can stroke a 283 or a 310 to 5.5in, but the oil holes in the crank wil have to be redrilled after the crank has been welded up and stroked. I know thw A series 283's have a wider main journal on thecrank, I'm not sure about the B and C series engines. Hope this helps
