Oliver 88 Hubs need to get rid of keyway
Hank L
10-24-2005 19:26:02
I am planning to put 88 Oliver hubs on a Farmall M so I can run steel pressed wheels. How do you narrow the keyway so it will fit the Farmall axle??
Mike S 806/H
10-24-2005 22:51:47
 Re: Oliver 88 Hubs need to get rid of keyway in reply to Hank L, 10-24-2005 19:26:02
I ground the key in the hub from a oliver 77 to fit my H, I used a grinder with a cut off wheel to cut a line in the key where I needed to remove part of the key, then used a regular grinding wheel to remove the extra,
Captainhookerus
10-24-2005 21:45:16
The times I have seen this done they ground out the keyway in the axle to fit the hub.
