1850 engine swap
Tal
10-23-2005 19:06:46
Our loader tractor an 1850 Oliver with a 310 diesel just lost the tranny. We are transplanting the loader to another tractor. I know of an 88 diesel oliver on its last legs. Will the 1850 engine fit into the 88. I know similar questions have been asked, but I did not know if the diesels were different.
ejr-IA.
10-23-2005 19:26:14
 Re: 1850 engine swap in reply to Tal, 10-23-2005 19:06:46
I thought 1850 diesels had perkins engines not 310 waukesha .Yes a 310 will bolt in a 88 frame with a few modifications,mainly the shaft between the engine and rear end have to be shortend.
Jeff Oliver
10-24-2005 05:09:26
 Re: 1850 engine swap in reply to ejr-IA., 10-23-2005 19:26:14
Yup unless it has been swapped the 1850 diesel is a 354 perkins. The 1800 used the 310 Waukeshau in it. Now i think the 1855? had the 310 in it that was turbo"ed or maybe it was the 1950, I can"t really remember. If it is the 310 it will fit in an 88 with a few mods.
Cody
10-24-2005 06:13:05
 Re: 1850 engine swap in reply to Jeff Oliver, 10-24-2005 05:09:26
An 1850 was available with a perkins or a waukesha diesel. A 1950T has a turboed 310.
A.P.
10-24-2005 10:42:25
 Re: 1850 engine swap in reply to Cody, 10-24-2005 06:13:05
The parts book I looked at shows only the 310 Waukesha gas/lp engine and the 354 Perkins engine available in the 1850. The 1855 used the 310 turbo"d diesel or the 310 gas engine. If there was such a thing as a factory 1850 equipped with the 310 diesel, then you would be better off restoring it or selling it to a collector.
tal
10-24-2005 17:43:52
 Re: 1850 engine swap in reply to A.P., 10-24-2005 10:42:25
Its a diesel, Not turbocharged. Its an 1850..... .....
Cody
10-24-2005 18:22:38
 Re: 1850 engine swap in reply to tal, 10-24-2005 17:43:52
If it is a 310 Waukesha, it will bolt into your 88 with a few minor modifications. I knew I had seen 1850's with 310D's in them. I guess you have a collector tractor.
Doug Boll
10-25-2005 14:23:39
 Re: 1850 engine swap in reply to Cody, 10-24-2005 18:22:38
Oliver never made a gas 1855 or1955. dsl versions had a turbocharged 310. Similar but 1955 had an in block oil cooler, as did most 1855's after they blew up the original motors. 1850 has a 354 Perkins, 1850 gas has a 310 Waukesha 3&7/8th x 4&3/8th, 310 gas or dsl.will fit 88 frame, the Perkins used a different frame. If you have a 310 dsl. in an 1850 either it's a transplant or it's the only one made!
tal
10-25-2005 18:56:18
 Re: 1850 engine swap in reply to Doug Boll, 10-25-2005 14:23:39
Perhaps it is wiz bang..... ...Its a NON-Turboed diesel. I thought the perkins was turbocharged. I'll try to get pictures and post.
BM
10-25-2005 16:31:51
Oliver made a 1855 gas
Doug Boll
10-26-2005 05:25:23
 Re: 1850 engine swap in reply to BM, 10-25-2005 16:31:51
I stand corrected on the 1855 gas, glad I don't have to feed it $3.oo/gal. gas!! The perkins dsl. in an 1850 is naturally aspirated. We have had 2 1850's and some Massey combines and have found no reason to dislike the Perkin's engine!
