How to figure compression ratio?
King Case
10-19-2005 18:20:14
I have seen on here in the past the formula to figure out the comp on a engine bfore you build it. Now i cant seem to find it. Any help is appreciated.
wolfman
10-24-2005 17:21:55
 Re: How to figure compression ratio? in reply to King Case, 10-19-2005 18:20:14
Volume of cylinder when piston is at very bottom of stroke : volume when cyl when piston is at top dead center; then change to ratio to something to one form i.e. divide both your measurements by the second-named.
ratio
10-21-2005 11:38:37
the ratio is
uncompressed volume(cc's) divided by compressed cc's. you havce to make sure you do the head volume, and use a piece of glass to fill it up cause it will remain flat and give you the most accurate reading.
jd b puller
10-19-2005 20:51:37
Forgot to mention, fill in the yellow squares, green is outputs.
And this will only give you the geometric, not the true PSI reading.
jd b puller
10-19-2005 20:46:18
See if this helps...
This is for a B, but should work with most.
Link
