for case lady
lafngas
10-19-2005 07:59:50
I was just woundering where you pull at and live I pull a super M and a H and a D john deere along with the G Moline that i have for sale on here we pull at tuttle and norman then all the showes harra, shawnee murry, i pull some in tx and ks when i can get thier would like to talk to you some Mike
Case Lady
10-19-2005 08:07:11
 Re: for case lady in reply to lafngas, 10-19-2005 07:59:50
we pull around the Tulsa area. We pull with CASTA - the truly "stock" club - can't be tweaking your tractors at all. However, we have pulled our MM some with Green Country, simply because it is a strong tractor and they have several different classes going from straight stock to open pocket book. You may have talked with Hubby about the MM you have on here for sale - his name is Brett and he called a guy in the OKC area about one a couple of months ago, might that be you?
lafngas
10-19-2005 09:23:37
 Re: for case lady in reply to Case Lady, 10-19-2005 08:07:11
Might of i cant recall that name tho yea i have not pulled with them yet i have a friend that pulls a massey harris 44 downt thier i want to pull with green country but thay stop at 7200 i was told i am building a B farmall now to pull 2600 or might do my massey harris 22 not sure yet I have a vac case two but needs alot of work. what all tractors do you pull.
topsarg
10-20-2005 04:45:14
 Re: for case lady in reply to lafngas, 10-19-2005 09:23:37
Hey lafngas... Green Country classes start at 2500lbs (Div II) with a speed limit of 3MPH. All others are 3.5 with except of the Open class which is 12MPH.
Case Lady
10-19-2005 10:16:19
Green Country pullers will weight up higher if you show up with a heavier tractor. We usually pull at 7600#. I pull a little VAC in the 3300# class with CASTA.
lafngas
10-19-2005 10:37:20
 Re: for case lady in reply to Case Lady, 10-19-2005 10:16:19
I did not know that was told 7200 was as high as thay pull. ok now you say casta pulls stock only? what weight can i pull thier do thay pull 2600 and up are thay all first gear pulls down here we can pull up to 4 1/2 mph start at 2600 and pull 3500 to 10.500 at a thousand pounds breaks cut tires in open class and no radial tires allowed. I own my own sled so we pull every weekend for fun at home when we arnt in the fields working.
Case Lady
10-19-2005 10:51:46
 Re: for case lady in reply to lafngas, 10-19-2005 10:37:20
we pull 2600#, 2900, 3300, 3600, 4600, 5600, 6600, 7600 and 8600 and most of the smaller classes have Antique and Classic categories both. Smaller classes speed limit is 3 mph, larger classes it is 3.5 mph. Most pull in first gear, but some pull in second and third gear as well - whatever you have umph enough to get the sled moving goes as long as you don't honk the horn or give sledjockey whiplash. No cut tires and everything is to be factory/stock. Now, tell me about your sled. We are thinking about putting one together over here just for fun pulls. During July and August, just about every one of our scheduled pulls got cancelled due to heat and hubby and I and a couple of others are wanting to put one together just for play. We got a good place for a track and are thinking if we can get everything together, we would put in some lights so we can pull at night during the heat.
lafngas
10-19-2005 12:01:44
 Re: for case lady in reply to Case Lady, 10-19-2005 10:51:46
Give me a call or have your other half and i will tell you how we made it only thing i would change on are sled is we need a bigger weight box or a water tank. 405-818-2701
Case Lady
10-19-2005 12:03:27
 Re: for case lady in reply to lafngas, 10-19-2005 12:01:44
Great! Thanks for the info. Brett will call you this evening bout dark-30!
