power block
Daryl25
10-16-2005 19:18:58
I have an unstyled A and have opportunity to get a #1 powerblock is there any thing I will have to change to make it work or will it bolt right up.
Drew
10-16-2005 19:33:09
 Re: power block in reply to Daryl25, 10-16-2005 19:18:58
It will bolt to the crackcase without a problem. I know for sure you will need a styled head and think you will probably need styled connecting rods w/ 1.750 wrist pins. You may also need styled pushrods; check the length of what yours are to styled peices and they may be close enough to work. If you plan on still hand starting it, you may want to put petcocks in it as power blocks do not come with them.
Other that those few things, I think you are pretty much home free.
Big Jugs
10-17-2005 13:32:35
 Re: power block in reply to Drew, 10-16-2005 19:33:09
I think you may also have to change the crank if you do that. Aren't the chanfers a little different on an unstyled? Maybe just re-bush the wrist pin bushing to the styled pin size. Probably wouldn't be a bad idea to go with new bushings anyhow. Just a thought.
Drew
10-17-2005 18:45:03
 Re: power block in reply to Big Jugs, 10-17-2005 13:32:35
I dont know about the crankpin radi, but if you are going for cubes anyway, a styled crank is an easy .250" stroke. It's only money (ain't that right Mike 'n Mo :-) )
And B.J., I've got a crankshaft story for ya :-(
Big Jugs
10-17-2005 21:55:09
 Re: power block in reply to Drew, 10-17-2005 18:45:03
Say it ain't so! Got the oil leak fixed in mine, just putting tie bars on. Will have new sidecovers to debut in Columbia, also a cooler full of????? ????? ?? Man, now you got me worried about crankshafts.
