Farmall M pistons
FARMALL COLLECT
10-13-2005 10:43:03
I am wanting to retain factory block and do it in frame.A 4 inch high altitude such as m and w ap62 or 61 is max under these parameters however I am not having any luck finding any?Case ih subs everything to 374515r93. Does anyone know the head configuration of this piston?Or to put it more bluntly how much compression will it add?I would like 200 psi with 8060 head.Everything else factory. Thanks.
DWV
10-15-2005 09:18:39
 Re: Farmall M pistons in reply to FARMALL COLLECTOR, 10-13-2005 10:43:03
Thats a fire crator gasoline high altitude piston & sleeve set number.
champspa
10-15-2005 03:53:53
according to webertractorworks.com on there tuneup info a lp head with flat top pistons should have 223lbs
randy hall
10-13-2005 20:55:50
i have a set of m+w pistons that are for propane that gives you 8to1 compression. the domes are an inch tall. i don't want to sell them but i have thought about having some made but they would be expensive. i could sell you a lp head for only a little more money and that would make more power.
B BARENIE
10-13-2005 19:49:14
CAN'T EVER GET THERE !
FORGET THE HUNT !
Flogger
10-13-2005 12:40:44
It would be tough to get 200 with off the shelf pistons and the 8060 head. The 450 lp head will get you close, but you can't have much of a piston dome with it. About your only other option is custom pistons. Given the choice I'd shop around for a lp head. It should be good for an extra 10 HP.
