SUPER M DRAW BAR
BUD BARENIE
03-10-2002 03:01:20
PULLING IN FARM-FIELD STOCK CLASS !
QUESTION ? IF I MOVE THE DRAW BAR ASSEMBLY CLOSER TO THE REAR AXLE HOUSING, WILL THAT SHIFT MORE WEIGHT TO THE FRONT OF THE TRACTOR ?WRITE NOW THERE IS ABOUT 2-1/4" FROM THE ATTACHMENT TO THE BACK OF THE AXLE HOUSING ! THAT'S THE STOCK CONFIGURATION !!! RULES STATE MY HOOKING POINT MUST BE 28" FROM THE CENTER OF AXLE HOUSING TO THE HITCHING POINT !!! I WANT TO MOVE THE ENTIRE ASSEMBLY AHEAD ABOUT AN 1-1/2" ANY ADVISE !!
John B.
03-10-2002 08:40:06
 Re: SUPER M DRAW BAR in reply to BUD BARENIE, 03-10-2002 03:01:20
We run a stock M [60 hp.] We find that ours pulls best in the stock location. You have to be able to lift the front end if your going to get full traction. I don't think 1/-11/2" is going to make that much diff.
bud barenie
03-10-2002 15:27:54
 Re: Re: SUPER M DRAW BAR in reply to John B., 03-10-2002 08:40:06
thanks for the reply 60 horse pretty good
how did you get there !! need advise
DCPULLER
03-12-2002 14:56:44
 Re: Re: Re: SUPER M DRAW BAR in reply to bud barenie, 03-10-2002 15:27:54
Well For one thing he's sure not stock. Is'nt it amazing how adding 15 to twenty horse power still makes you stock to some people .
Get Serious
03-15-2002 21:39:17
 Re: Re: Re: Re: SUPER M DRAW BAR in reply to DCPULLER, 03-12-2002 14:56:44
Guess DC doesn't do any pulling, only showing. 60 hp. M would be considered stock in the div. 2 class. Div. 1 is for the "pure stock - show stock" class. They worry more about scratching the drawbar than real pulling. To each their own. That's why there are divs. in ant. pulling. Theres a place for everyone.
John B.
03-12-2002 21:35:10
Other than milling the head, we worked on the gov. & carb. It's not bored or stroked. More time than money invested. If you don't believe me buy it. With the wheelie bars & wt.rack ready to pull div.2 $1400.00 would take it home. Tractor did well at the Dekalb Super Pull. Around here We're on the bottom side of the hp. chart.in our class. [N.E. Ind.]
John B.
03-16-2002 16:36:46
 Re: Re: Re: Re: Re: SUPER M DRAW BAR in reply to John B., 03-12-2002 21:35:10
Theres a picture of the Black M on the "pullsite.com" site. Look at the Dekalb super pull pictures # 74. Results are on the COATPA.COM site.{6500 div.-2] You can see from the picture I was about 75lbs. to heavy on the front.****hindsite = 100% ****
