Turbo Farm
Nothing Runs Li
10-09-2005 13:40:02
As many of you fellas have seen in my posts I am in the process of selling my G and moving into a larger class. The class that I intend to move into is the Turbo Farm class; a class that is fairly new to my area.
I have a few questions for you that have had this class longer then I have.
1. What tractor dominates the class?
2. What are the rules in your area?
3. What are the weights in your area?
My plans are now to build a 5020/6030 over the winter. I am looking closely at the 5020 that is for sale on this very website.
Give me any info you got on Turbo Farm
binderboy
10-10-2005 10:46:22
 Re: Turbo Farm in reply to Nothing Runs Like A Deere, 10-09-2005 13:40:02
There is a guy in central Indiana that has got a 5020 with a turbo that can hang with just about any 66 series I/H or 30-55 series Deere and is still utilizing a rotary pump/pencil injectors.
Seems like he is balanced just slightly heavier than a 30/40 series Deere, which is impressive considering the amount of meat on the front axle.
I know he crosses the river (south) every once in a while and does pretty good in some more open/non-mph classes.
Most of the pulls in central/southern Indiana are 5-6 mph/20" up and 18" back drawbar/with 12500-15000 weight classes/20.8 tires/3000 rpm, although there are the occasional stock or stock + 10% rpm classes.
Everyone is pretty even for the most part>>one guy out in front one pull and 5th the next one, etc.
Bad thing about 6030 is the weight and balance, good thing is the amount of fuel and motor.
Good luck.
Ironman
10-10-2005 09:32:41
What are the rules in your area? I.e., weight, engine, turbo, etc?
ejr-IA.
10-09-2005 14:56:12
If you like deeres this is what I would do is go with a 4010 or 20 with the 466 with the p pump and other goodies.If you use the 50 you will need a 619 to get the job done + a big trailer and pickup to haul it.
G/MAN
10-09-2005 14:41:09
There are a few stout 6030s in my neck of the woods in southeast Nebraska. Most of the pulls are more "farm" pulls. Rules call for specific drawbar length and height requirements, must have a working rockshaft and PTO if factory-equipped, etc. No dual wheels, no MFWD. No limits on engine size, speed, shifting or anything else, though. Weight classes top out at 15,500 or 18,000 depending on the pull. Lots of Deeres and Binders, with a a few of the other colors mixed in. Deeres from 20-series through 55s, and Binders from 06s through 86s. Anybody's game in the lighter classes, with the Deeres usually cleaning up above 13,500. On particular 6030 and a 4640 Quad-Range go back and forth most of the time with the win in the heavy class. But, there are some pretty hot small-frame 40s, 50s and 55s that will hang right with them a lot of the time. 4055 and 4255 Power Shift tractors have a LOT of potential. For whatever reason, the IH guys usually don't pull in the 15,500 or 18,000. 6030s are stout, but you're stuck in whatever gear you pick. Usually they have enough smoke to lug it out, though.
856 puller
10-09-2005 14:47:12
 Re: Turbo Farm in reply to G/MAN, 10-09-2005 14:41:09
G/MAN just wondering what trans is perfered in the deere can they make the 15spd hold big power?
G/MAN
10-09-2005 15:55:09
 Re: Turbo Farm in reply to 856 puller, 10-09-2005 14:47:12
As I said, this is more farm pulling than anything else so it's not like anyone is running 700 horsepower or anything, but yes, the 15-speeds seem to hold up just fine. A trip down the track isn't any harder on them than a full day in the field. Some guys prefer the Quad-Range, and some like the Power Shift. In certain models, the Power Shift is the only transmission available, for that matter.
G/MAN
10-10-2005 10:25:33
 Re: Turbo Farm in reply to G/MAN, 10-09-2005 15:55:09
Several of the tractors pulling where I'm from are pretty much pull-only machines, but they still retain most of their functionality and COULD go to the field if needed. The rest are all working tractors. I get more enjoyment watching a tractor that does real work than a toy where's there no serious consequence if it breaks. Talked to a guy one night that smoked the clutch in his 1086. He was going to spend the next day replacing it so he could bale hay.
856puller
10-09-2005 16:46:40
here the 6030s and 5020spull 7th and 8th gear and if they told me they had 600 hp i wouldnt doubt it smoke flame and speed they make a good show. i know that ih had to go to a gear type trans. but they are pull only tractors they dont really have the right name i guess
856PULLER
10-09-2005 14:23:04
IN OUR AREA its the 13000 open farm 3000rpm i forget the turbo size but the 6030s were the ones to beat. than a 7140 ih was built and has been wining by a lot! ever since, after he got the trans problems fixed.
856 puller
10-09-2005 14:25:34
 Re: Turbo Farm in reply to 856PULLER, 10-09-2005 14:23:04
i also know of a 5020 for sale it would be a good fixer upper in Mi
10-09-2005 16:46:17
 Re: Turbo Farm in reply to 856 puller, 10-09-2005 14:25:34
What are they looking to get from it? Price wise and what kinda shape is it in?
856 puller
10-09-2005 16:53:11
 Re: Turbo Farm in reply to Nothing Runs Like A Deere, 10-09-2005 16:46:17
its kind of ugly from i rember its a friend of mine i can find out and send pics if you open your e mail
10-10-2005 10:59:53
 Re: Turbo Farm in reply to 856 puller , 10-09-2005 16:53:11
Here... [email protected]
Thanks for the help.
