Oliver 880
ejr-IA.
10-09-2005 10:50:52
Building a 880 gas,offset ground crank to fit 770 rods,1800 diesel sleeves and piston,1600 head. ? How much clearence do I need between piston and head to be safe.I'm above deck now and need to cut the pistons down,they are flat tops.
Cody
10-09-2005 11:16:19
 Re: Oliver 880 in reply to ejr-IA., 10-09-2005 10:50:52
The head clearance needed depends on how much piston-cylinder wall clearance you have. I would stop them flush with the block, just incase your pistons rock a little. You should have more than enough comp. with the 1650 head.
