Running Alcohol
JaredM
10-07-2005 16:23:39
I might be opening a can of worms but what does it take to run alcohol. Just curious. I've heard you have to advance the timing 5-8 degrees, bore the carb jets about 30% over, get a hotter ignition system, and make the compression ratio between 10:1 or 12:1. Is that all or is there more? Also what kind of ratio does a stock c264 high comp IH engine have? Can you put the 4 1/8" overhaul kit for a 450 in this engine or would I have to bore it? What are ways I can raise compression? What are the costs of stroking the crank and planing the head? Don't think I'll run alky just wanted to know whats involved. JaredM
